Turbo rings in a N/A L28?
Zmanco
I've had a heck of a time finding rings here in CO for my flat top pistons in my N42 block. After returning the wrong rings twice (both times with L24 rings in an L28 box) we've found a new source who has Perfect Circle chrome rings. But they only stock the turbo set, not the N/A ones. They (the warehouse) says that the only difference is that the turbo set has a chrome second ring where the N/A is cast iron. They say that there's no issue with this, and that seems to make sense to me.
But before I put them in I wanted to check here to make sure I'm not missing something. I'm only planning on this rebuild once :)
BTW, the shop honed the cylinders for chrome rings.
I believe that's true for the NA 75-80 where the top ring is 2 mm. But the flat top pistons in the 81-83 NA are 1.5 mm which I believe is the same as the turbo. Any of you turbo guys out there able to confirm that?
