Tranmission Swap
Guest Jim226
Guest Jim226
I know that this has prob been posted before but I have looked around and not found the exact answer I'm looking for. I currently own a later model 260z with an automatic transmission, I'm interested In swaping it out and putting an early 260z 4spd tranny in. Now I do have the parts car which has def. seen it's better days......But what exactly is required in doing the swap properly? Do I need to use the manual starter or not? and what else is required? I have the clutch master cylinder, slave cylinder, pedal box, etc. I ask the question about the starter because the one thats on my parts car is really old and beat up looking and I doubt it works, but I have not tested it. Any help would be great I plan on doing the swap this summer and just want to be sure that I get everything required. If I missed anything please let me know.
same starter...
clutch pedal and brake pedal box assembly
clutch slave cylinder
pilot Bushing (end of crank)
clutch lines
flywheel
clutch
pressure plate
shifter
clutch fork
throwout bearing collar
throwout bearing
and thats about it.. someone fill in the blanks if i left something out
manual trannys are soo easy ;)
