No spark
My 70 240z with unilite dist. and promaster coil is not getting spark. I do have the ballast resistor and just ordered a new one online to see if that was the problem(much smaller than one that it came with). The car has not ran in a year since i put the original l24 back in. i tested my module and it was bad and smelled fried before tested, so ordered a new one of those thinking that as the problem. After hooking up per instructions, when cranking no spark from coil wire to ground and the ballast resistor begins to smoke and is pretty hot. I have it grounded correctly and wired 12v one side and then to + coil other side.
I have searchd around for ways to test my coil and when it was hooked up and in run position i grounded the - on coil an still no spark. I am thinking my coil may have also bit the dust. Is there a way i can verify this with some mulitmeter tests. Someone please help me figure out what is going on. If someone could help me out I miss my car!!!
