custom chassis?
Does anyone know of a shop that will fabricate a custom aluminum ladder frame w/ roll cage, or an aluminum backbone frame? What would the weight reduction, and stiffness increase be? Are the benefits worth the cost?
i have no idea who would make one from alum. i know someone who made a full tube chassis to fit underneath a Z roof and door pillars. this IMO would be a better way to go. it used all stock suspension pickup points (i owuld have changed some of this)
the price was $5500 to get the car back to a roller. this included the full tube chassis and cage is obviously integral with this.
Mike
mike@fonebooth.com
http://www.fonebooth.com/brakes.html
raceparts and brake upgrades.
OK, maybe aluminum isn't a good idea. I was looking through some books on chassis design and they had several aluminum backbone frames for race and street cars (one was for a Cobra). Having no real experience with frame fabrication, I thought this could be a possibility. Not a single person I've talked to has said using aluminum would be practicle. Does anyone know of a shop that will fabricate a steel chassis?
Just about any decent chassis shop ough tto be able to undertake this. Talk to some of the drag racers in your area or better yet the circle track guys. Even out here we've got folks that can do this - it takes time and piles of money but when they're done you've got a shell of a car and a jungle gym inside smile.gif Last I saw they were doing a shoebox Chevy of about 1956 vintage. Cut out the whole floorpan and the firewall forward was nothing but tubing. Very nice but NOT cheap. Great way to change the suspension to most anything you want I suppose. 'Vette rear anyone?
Yeah, the original Cobra used a spine backbone monocoque frame of stainless steel alloy (according to a AC Cobra site history: http://www.xs4all.nl/~luukb/ac.html )surrounded by hand hammered and english wheeled aluminum body panels. It was fairly stiff, cramped and ungodly fast.
As far as a custom shop to hook you up with a frame, I'd start locally, let your fingers do the walking in the automotive section of your yellow pages. Most of the larger cities will have plenty of chassis fabrication places. Good luck on your project.
Respectfully,
Lone
The only frames usually made with aluminum are monocoque and that's a whole other ball of wax. It requires adhesives, riveting and generally a scratch design/build as its basically a lot of aluminum panels strategically riveted together (I.E. Indy, F1 cars, although most use composites in place of aluminum now a days.). Spaceframes can be done in aluminum but the bodywork would need to probably be fiberglass panels. Still some (lots!) of riveting and adhering of panels is required. An example of this would be the inventor of the Locost (scratch build Lotus 7 replica's). He has built a all alloy spaceframe, used a Honda Fireblade motorcycle engine (1000cc Inline 4, water cooled about 130+ hp) and claimed weight dry is 300Kg (what about 660 Lbs!). Obviously that's an extreme example, but its a cool concept. You can see this at:
http://www.ronchampion.com/alloy_Gallery.htm
and read about it:
http://www.ronchampion.com/main_frames.htm
If you haven't seen or read about them, do a search on Locost on the web, these little cars are pretty cool.
Regards,
Lone
Lone - one interesting thing to note about the Cobras, after awhile that nice skin had to be REPLACED! Yup, that's what happens when you bolt steel to aluminum or vice versa - electralosys (sp?!). The two different metals set up a current and end up eating one another up. Something to bear in mind with aluminum radiatorsheads and steel blocks...
Wow, yeah I knew a little about disimilar metals and they're interactions but didn't know the Cobra's rotted that way. Man. That would suck. (specially on a original that you'd have to pay a mint for.). Theres a american guy thats creating a cobra replica in (I'm guessing cause I can't remember for sure, its like poland, or russia)at a tooling plant there. I guess it was cheaper to do there and they had the tooling.
Anyway, they were surprised when they measured an original body with a 3d scanner to find they weren't the same side to side. Could have told them that, hand formed cars while they look symetrical, they're not, it depends on the craftsman and how close he got it to the forming buck and whether he said 'close enough' or not. Production tolerence I guess you'd call it. smile.gif
Lone
