springs
Guest Anonymous
Guest Anonymous
Anyone got an opinion on which springs are the best? I'm talking OE dimension springs, not coil-overs.
I can't bring myself to pay the exorbonant fee for coil-overs, so I figure I'll just get normal springs, if they're stiff enough.
Anyone know the spring rates for various aftermarket springs?
Morgan
http://z31.com/~morgan/s30
http://carfiche.com
i hve a set of eibach prokit springs laying around for 75-78 z.i liked the ride but changed to coil overs for track use.it takes struts with good rebound dampening though.i used tokico 5 way illumina and had to run the rear on position 3 to control rebound.the front i ran full soft on street
I have Suspension Techniques springs on my '71. For me they are about the ideal compromise for street and track usage. They're twice as stiff as stock at 160 lb/in front and 200 lb/in rear. They lowered the car about 1", again about what I was looking for as a street/track compromise.
Dan Baldwin
'71 240Z 3.1
COMSCC #7 SPB
240 and 280 are different spring kits.
the 280 are usually stiffer for the heavier car.
also the 280 rear strut is longer and in some kits the spring is shorter.
the susp tech kit is probalby the best but if randy is ging to sell his cheap $125 set or so then try them just will need a set of good inserts as he states...
i heard a rumor a while back that tokiko bought susp tech. so the springs now made arent necesarily the same as the ones most have from years ago..... tokiko has them made in different places and the quality varies.
i sold susp tech alot in the 80's they were fine, now they dont seem the same. i have triewd tokikos and didnt like them and eibachs and didnt like them either (coil bound)
Mike
mike@fonebooth.com
http://www.fonebooth.com/brakes.html
raceparts and brake upgrades.
