problem with CAS dizzy on MS&S_E install...
Mack
so, Im looking at the wiring diagrams and how to wire it to my V3.0 board and I noticed that my wire colors dont match those on either of the diagrams (lost souls on the DIY site or Mobys excellent sticky) I have white, green, red, and black wires.
if i hold the dist in my hand, with the rotor pointing away from me and the plug facing up, the green wire is above the white wire on the left and the red wire is above the black on the right.
can anyone help thanks in advance!!
THANKS!
I am using a spare N/A wiring harness and I am going MS&S_E on my NA car. Im using the AFM wires for the dist and ignition wires, since I wont need them anymore, lol!
It just clipped the plug off of the ECU end and soldered the appropiate wires to the appropiate places on the DB37 connector.
also, the stock wiring powers all the injectors on a seperate hot wire coming from the FI relay and the stock ECU just grounds them, so I kept the injector power seperate from the ECU power. shouldnt be a problem, eh?
