What do I use to seal frsh cut holes in metal
Guest brad101010
Guest brad101010
Hey there, i wanted to get some feed back as to what i should use to protect the fresh metal that is exposed when you cut or drill sheet metal.
Thanks for your help
Guest manntis
a coat or two of paint, left to dry before screws or bolts are installed, will help. The pressure from screws or bolts will be in the metal surface beside the hole, not on the exposed rim of the cut.
Is that your Z in your sig, AK-Z? It's 12 shades of gorgeous.
I don't know how many times I get asked that. Its a CG rendering (not real). Mines far faraway from looking something like that.
Check out the link in my sig to watch a video of a rendered one.
