rotor vs. piston Posted May 12, 2006 Share Posted May 12, 2006 I have the pdf of the s13 engine harnes and I wired the relays according to the pins on the ECU side and matched them with the nubers on the relay. But when I turn the key on the relay's do not click on, the ecu is coming on from the other power wires. But it's not giving power to the fuel pump circute... I had a 12v bulb to signal me... then I put my DVOM to verify that nothing was coming out of the signal wire from the ECU. BTW is that a ground or power? I cut a fuse/relay box off a S13 because I thought it would make wiring easier, but no. Also the pdf calls fror in ignition relay and ignitor (IIRC) relay, but these are not in the S13 fuse/relay box and never mentioned on any of the "how to guides". I noticed that the ignition relay is in the cabin... so I'm assuming the s13's not nessasary for my sway. But what about the ignitor relay. This swap is going in a NON-NISSAN vehical if that help any. Quote Link to comment Share on other sites More sharing options...
rotor vs. piston Posted May 13, 2006 Author Share Posted May 13, 2006 got it... now I need to put it to paper so when I go back and make it permanent I can see how I wired it. Here's to hoping that the car starts today. Quote Link to comment Share on other sites More sharing options...
