only one injector bank firing
Chaoticmass
Got the other issues with my Megasquirt solved-- still trying to start the car.
After cranking plugs 1 - 3 would be wet. Plugs 4 - 6 would be dry. All injectors have power, but it seems as if only one bank is firing.
Rewired it so Banks 1 and 2 were swapped, now plugs 4 - 6 are wet and plugs 1 - 3 are dry. Certainly seems that only one bank of injectors are firing.
Any ideas whats wrong?
Car wants to start... we got spark... and we have fuel on half the injectors.
What version board are you running?
2.2
Are you using series current limiting resistors?
no, using flyback board
What are you PWM settings?
probably incorrect. What are the right settings? I dont know what I'm doing here. What part of the documentation/manual speaks directly to how these settings are supposed to be set?
Which driver is driving what injectors?
I dont know what you mean. Everything is setup like in MobyTheVan's sticky except running MSnS Extra. Using Optical dizzy. GM HEI module.
I hope this information helps you help me. 2006 convention is coming up and I am running out of time.
