trwebb26 Posted May 30, 2006 Share Posted May 30, 2006 I have a 78' 280z and I am going to install the Modern Motorsports Coilover kit. My hopes: - Something that will kick *** at the autocross or drag strip... I'm not as concerned about ride quality, but don't want it to kill me either. Performance is the key for me. - I want to drop the car to get rid of the nasty wheel gap, and I also want to run wide tires. - I will be sectioning my rear strut tubes and moving the A-Arm location (the typical modifications). The questions: - What would you reccomened for front/rear spring weights? - 8" or 10" springs? What is the tradeoff? Does the strut section make a difference? - I want to run adjustable shocks. What is the correct car to buy for assuming the struts will be sectioned... I've heard that miata shocks are correct for sectioned rear strut tubes? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted May 30, 2006 Share Posted May 30, 2006 might want to check out this sticky, it will answer a lot of your questions http://forums.hybridz.org/showthread.php?t=106354 Quote Link to comment Share on other sites More sharing options...
