badjuju Posted June 9, 2006 Share Posted June 9, 2006 1981 280zxt. Looking at the ignition module on the side of the bracket which holds the ignition coil, If you look at the T connector, I am wondering where the black wire with a white stripe goes... I have tested it to ground, and I get 25 ohms. So, i am thinking that the wire just goes to ground. Also, I'm wondering which wire (yellow with a white stripe and Black with a white strike) goes to which terminal on this picture: I cut the connector a long time ago and now i'm having trouble with which is which. My FSM is of no use on this one because it doesn't even have my ignition setup in it. Quote Link to comment Share on other sites More sharing options...
