spotfitz Posted February 12, 2001 Share Posted February 12, 2001 After getting the stub axle back in and the calipers bolted down I found out that I had acouple problems. One, the e-brake cable was running right through the hard line/flew line connection mount on the frame. After drilling out the spot welds on the mount(PITA) I managed to move the mounting bracket to a better spot. I then noticed that the brake line mount on the stub housing was running the flex line right into the caliper. I thought I would just take the mount and bend it over where the flex line would run underneath the caliper. Worked great. Then I tried to hook up the hard line from the flex line to the caliper. Well, the ZX caliper doesn't have a flare fitting on it for my early Z hard line to hook up. I went to the junk yard and got the end of the flex line that went to the ZX caliper and took it to the hardware store where I found (2) 8.8 grade bolts w/ 1.00 pitch about 1" long with matching nuts that all matched the ZX flex line. After taking the bolt to the shop and drilling a hole straight down the middle for the brake fluid to flow, I cut the head off the bolt. Now whats left of the bolt will thread into the caliper with the nut securing it tight(and allowing for removal with another nut). I will do away with the hard line that is between the flex line and the caliper and just hook the flex line to my make shift adaptor. ? is, what is the pitch of the flare on the flex line? I have a double faring tool, but it won't flare this bolt. If I just leave the flat end of the bolt I'm sure it will leak. What do you think of my adaptor? What has everyone else done with this set up. Quote Link to comment Share on other sites More sharing options...
