Brake Distribution Block Replacement
Every since I put stainless steel lines in the car, I have not been able to get the brake distribution block to seal quite right. I have the lines about as tight as you can get them and it still leaks.
I did notice the seats inside the block had very shallow nipples compared to some of the other brass fitting I had laying around.
I'm tired of fighting this and want to replace the block with two fittings. One is going to be just a straight piece and the other will have to be a three way fitting.
Anybody know where you can get this weird metric pipe thread fittings?
When I was replumbing my brake lines and eliminating the prop valve, I was never able to locate a metric T for the double flare lines. You can find the bubble flare ones all over, but no doubles. I wound up robbing one off the rear of a parts car, where the rear lines separate.
John
