Camber question
I moved the pivot location of the lower control arms in the front crossmember. I moved each hole 15/16" up and 3/8" out.
I thought I had measured precisely - I even made a sort of a jig helper tool to locate the hole with a washer based on the factory hole.
Anyway, I just got the car aligned and the report shows a difference in camber of 0.4 degrees between left and right. Is this bad? Should I be concerned? I hope not, bucause taking everything a part, welding up 2 holes and redrilling them is really alot not appealing....
240Z.jeromio.com
i wouldnt worry about .4 unless your at 2 degrees total...you would want about 1 for a street car..
theres always variations in cars thats why heims or camber plates are commonly used. slotting is a one time go..
Mike
