Guest Zedhead Posted July 8, 2006 Share Posted July 8, 2006 I have a '72 that I am doing a coil over and '82 280ZX disc brake conversion on. I am using the Maxim bracket which places the caliper in the forward most position on the brake disk. While test fitting I found the E-brake cable will interfer with the brake line. There is a tab welded to the frame that supports the connection between the braided steel line and the brake line on the frame. The E-brake will crash into this when the strut is collapsed. I assume I need to move this tab. Does anyone have a recommendation as to where to relocate this tab? Has anyone dealt with this issue before? Thanks, Zed Quote Link to comment Share on other sites More sharing options...
Cyind Posted July 9, 2006 Share Posted July 9, 2006 See if some of this post might help you! http://forums.hybridz.org/showthread.php?t=69813&highlight=280zx+e-brake+problem Quote Link to comment Share on other sites More sharing options...
spotfitz Posted July 9, 2006 Share Posted July 9, 2006 Using almost the same setup I relocated the bracket to the bottom side of the rear frame rail, if you want to call it that, just in front of the strut. The only difference in my set up is that I modified a '88 Maxima bracket to duplicate the '84 with a 15mm offset. PM me for pics. Quote Link to comment Share on other sites More sharing options...
Guest Zedhead Posted July 9, 2006 Share Posted July 9, 2006 Spotfitz, Yes, I would love to see some pics. You are saying you relocated the tab for the brake lines to the bottom side of the frame rail? Where did your caliper end up? It looks like the caliper would like to ride in the 7:30 position. This is looking at the drivers side rear wheel with 12:00 straight up and 9:00 where the Maxim bracket looks like it wants to put the caliper. Quote Link to comment Share on other sites More sharing options...
spotfitz Posted July 9, 2006 Share Posted July 9, 2006 OK, here we go. I'll have to pull these down in acouple weeks due to the size and lack of time to down size them. http://album.hybridz.org/showphoto.php?photo=8314&cat=500&ppuser=7958 http://album.hybridz.org/showphoto.php?photo=8312&cat=500&ppuser=7958 http://album.hybridz.org/showphoto.php?photo=8313&cat=500&ppuser=7958 Remove the old bracket from the body. Remove the hard line from the strut bracket to the stub axle bracket. Remove stub axle bracket and relocate it to the body. The flex line will now come from that relocated bracket on the body directly to the caliper. I ran like that for about a year before paint jail acouple years ago, with no problems or rubbing except for a slight clearancing I had to do where the emergency brake lever on the caliper came in contact with the body. See first pic. Quote Link to comment Share on other sites More sharing options...
Guest Zedhead Posted July 9, 2006 Share Posted July 9, 2006 Spotfitz, Far out. I test fit with your tab location and it looks like the way to go. Thanks, Did you weld the bracket back into place? I am afraid I'd burn a hole in my gas tank and burn the house down. Cheers Quote Link to comment Share on other sites More sharing options...
spotfitz Posted July 9, 2006 Share Posted July 9, 2006 I just reused the bolts that held it to the stub axle housing. Drilled the holes for them and used a tap for the threads. Quote Link to comment Share on other sites More sharing options...
kutukutu1 Posted May 17, 2017 Share Posted May 17, 2017 I am having the same issue. Spotfitz, can you send the pics you loaded? the link no longer work. Thanks Quote Link to comment Share on other sites More sharing options...
