Idle Oil Pressure Low <7psi
trwebb26
I can't believe a turbo pump didn't increase oil pressure at idle.
Are you sure it is a turbo pump? My low pressure idle issues were solved/improved by a turbo pump.
The turbo pump has longer rotors than the non-turbo pump. I forgot the exact amount but it is around 1/4 inch (6mm) longer. Maybe you should measure the new pump rotors versus the old pump rotors.
I run 15w-40 diesel engine oil in my Z.
The next time you get an engine rebuilt, tell the machine shop to install each bearing then mic the bearings and then turn the crank to get exactly 0.0020" clearance on all the main and rod journals. Cost a little more but worth it.
