Bypass hose for heater bypass
Ok... I've been reading and reading posts and I get that simply looping the heater core inlet and outlet lines is very bad.
I read more and I found that you should just cap them.
Then I read more and Tony D says you must have a recirculation line of some sort... so does that mean I can't just cap them???
The "vacuum capsule" on my 78 280z keeps leaking after I took it completely apart, cleaned the mating surfaces, and put sealent on the outer o ring (the one I thought was causing the leak.
Is this part replaceable? It's a vacuum activated valve for heater core flow. I found a similarly shaped one for GM vehicles that is practically the same except it is missing the mounting bracket.
Ideas?
Mario
