335 tires
interesting! Looks like a 79-up mustang rear suspension except the straight arms are up top instead of down low like on a stang. Only thing that would worry me is the bottom links and tabs they mount to distorting because the axle will naturally want to pull back on them under acceleration. I believe thats why the stangs use straight bars on the bottom as the angled arms will be a lot more effient to push against instead of being pulled against.
The Mustang uses kind of the inverse design, yes. The upper arms are the angled arms, but they converge at the axle housing rather than at the frame. This gives less axle support in lateral motion. Having the upper arms angled also results in a roll center height above the axle centerline. By angling the lower arms, your roll center height will be below the axle centerline. By having the arms connect at the ends of the axle and point in towards the center of the frame, you get better lateral support.
Yeah, the lower arms are doing double duty as both the lateral location device and helping control axle windup tendencies. On accelleration the lower links will actually be in compression (pushing on the frame). I haven't built it yet, but the lower frame mounts will tie into the structural transmission tunnel for added strength. I should have mentioned that before... without extra bracing those mounts do look a little flimsy!
The Mustang uses kind of the inverse design' date=' yes. The upper arms are the angled arms, but they converge at the axle housing rather than at the frame. This gives less axle support in lateral motion. Having the upper arms angled also results in a roll center height above the axle centerline. By angling the lower arms, your roll center height will be below the axle centerline. By having the arms connect at the ends of the axle and point in towards the center of the frame, you get better lateral support.
Yeah, the lower arms are doing double duty as both the lateral location device and helping control axle windup tendencies. [b']On accelleration the lower links will actually be in compression (pushing on the frame).[/b] I haven't built it yet, but the lower frame mounts will tie into the structural transmission tunnel for added strength. I should have mentioned that before... without extra bracing those mounts do look a little flimsy!
Woops I had a brain fart when I wrote that above. You are correct. Looks like a slick setup!
