83 turbo dist. swap?
Guest rickh77
Guest rickh77
I have a 1981 L28ET with the crank mounted CAS and a 81 distributor. I've been able to get a hold of a 83 distributor so I can run megasquirt on it. However, I don't have the oil pump drive shaft for the 83 dist. Does anyone know a good place to get one, or is there any way to swap the CAS from the 83 dist to the 81?
