Head choice.. N47 vs. P90
defrag010
I bought my 1980 280zx with a blown headgasket, and it came with a freshly rebuilt P90 head to put on. It's not running yet, but I had originally planned on putting the P90 on. However, this car is going to stay n/a and is basically going to be a daily driver which won't recieve very many mods.
Should I sell the P90 head and use the N47? If so, how much do you think I could get for the P90? It's fresh out of the machine shop, and has upgraded outer valvesprings on it but doesn't have a cam.
  • Administrators
If that engine is original, most likely the block has the dished pistons and if so, then keep the N-47. For an N/A application with the OE dished pistons, the standard Z car N-47, the N-42 or the E-88 are really your only options. The P-90 with those pistons gives you nothing in the way of performance unless you add boost as it will drop your compression ratio “below” 8:1.
If long term performance enhancements are in your future including an engine rebuild, then I recommend you keep the P-90 and keep a sharp eye for a set of the European flat top pistons.
HTH,
