made a little video of my n/a turbo
Guest dan4011
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
started up my car and had a drive this weekend, it was going quite well. a few minor issues to be sorted out though. tomorrow i'll be installing the rising rate fuel pressure regulator (which is on a slightly higher ratio than 1:1. the efi guy recons it will do for my car, and it should reach the fuel pressures required)
with the standard n/a setup it will run fine untill it gets into the boost. it misses and splutters a fair bit (but i've been keeping off the boost for obvious reasons)
for some reason its blowing lots of smoke and fouling plugs really bad. i'm gonna take a good look at the efi system tomorrow to see if i can sus out any problems. it seems to be fueling up when i try to start it
