pullup voltage confusion
trwebb26
With a properly installed 1K pullup resistor installed on the G/B wire as is shown in Moby's sticky - what should the voltage of that wire be if you check it at the distributor (with the car off)? I've only got 4 volts?
The black and white wire has 12v.
Very wierd... With the megasquirt on - it reads 4.0 volts - but if you unplug it - it goes to 12 volts. How is that even possible with the pullup constantly feeding it 12v? Can somebody check the voltage at the dizzy with the megasquirt on - and the car off to check if this is correct?
