HEI module necessary for V3 pcb?
olie05
From what I have read the HEI module allows you to convert an AC VR sensor signal into a square wave signal.
if that is true, why can't we just use the optical distributor with the available "optical input" circut option for the V3 pcb, thus eliminating the HEI module?
  Quote
50. Next you need to make a decision. There are two input circuits for the tach signal:
  • The Hall/optical/etc. circuit takes the square wave input from a Hall sensor, optical sensor, or points. It can also be used for triggering off the coil (but only if you are not controlling ignition timing).
  • The VR circuit takes the AC signal from a variable reluctor sensor and converts it to a square wave for use by MegaSquirt.
The Hall circuit can be built two ways - for a digital signal such as a Hall sensor or optical sensor (step 50.a.) or for a coil negative terminal (50.b.). these are the same circuit, but different components.
