Gas Gauge is not accurate
Guest zarstick
Guest zarstick
Hello,
I just replaced my 73 240Z gas tank sending unit with a new one and it does the same as it did before, that is, reads about 1/3 too low. It works but is not accurate, when I fill up the gauge will only read between 1/2 and 3/4 full, when the gauge shows empty there is actually about 1/3 of the tank remaining. Anyone have any ideas? Should I bend the arm on the sending unit to calibrate it? Thanks
