Guest nustad Posted June 18, 2001 Share Posted June 18, 2001 Hello all, I have a 72 240 and have just bought some Watanabe 15inch minilight style wheels which were too cheap to pass up. The only problem is the offset - they will fit on the car but are tucked under the guards a little too much. I want to put in some spacers and were wondering how wide can you go with stock wheel studs? If I replace the wheel studs what is the range of spacer width I should consider without affecting things adversely? Finally if you change the track measurement of the car does it make much difference to handling? I am beginning to wonder if going cheap causes more problams....... Cheers Glenn Auckland New Zealand Quote Link to comment Share on other sites More sharing options...
