air pressure regulator
Guest dan4011
allright, is there a need to have the stock air pressure regulator on a 76 with the turbo motor and a 60mm weber tb. the book says it adjusts idle speed during start up or something. my new tb doesent have the means to hook it up, at least not unless i use a stock coupler with the hookups for it. think i can just pull all of this mess off?
thanks for the help.
If it gets cold where you live and you need to drive in those conditions, you might wanna consider retaining it. When the oil is thick the engine idles slower. The air regulator bleeds air past the TB until the bi-metal warms up and closes the little door. If you wanna hold the throttle with yer foot for a few moments until it will idle, that will work 2
