FORD LIGHTNING 18X9.5's make em fit??
I'm wondering about that 5-lug front conversion and if there may be a more suitable source for hybrid hubs/rotors that more closely approximates the original Z front geometry (15mm offset). I'd like to know if setting the hub flange more outboard then running higher offset wheels preserves the geometry (roll center,etc) or not; engineers? I know that using higher offset rims than stock, without a hub change, makes the car have a mind of its own and it tracks off at random along any crease in the pavement it sees.
DAW
Wheel bearings/spindle-sizing is one of the largest overlap areas of commonality between different makes of cars that there is. There's really only a few different wheel bearings and there are only a few manufacturers. I'm exagurating some.
Use the grease seal on the donor hub, the inner diameter is shared and (common) bearing size dependent. If it has 12mm x 1.5 thread wheel studs (instead of Nissan's 12mm x 1.25), then use the donor's lug nuts.
Theoretically, if you want to replicate the initial geometry, then a 5-lug hub would need to be from a vehicle with similar OEM offset wheel geometry. Considerations for the Zcar would be: Crown Victoria,
Conquest/Starion, Mercury Marquis, SVO Mustang, Tbird Super Coupe, etc. All are 5 x 4 1/2" bolt circle. Go for the one with the best/lightest OEM alloys. It takes a trip to the junkyard, measuring with calipers, rulers, etc. The best junkyard is a large one with some of every kind of car so that you can pull a hub/rotor off one type of car, and carry it over to a Zcar
where you install & measure for clearance/interference and caliper position.
DAW
Couple of things... I believe the SVO Mustang hubs were from a Lincoln, I know some of the other suspension parts were so you might find those cheaper icon_smile.gif
None of the hubs you mentioned were trucks - guess what those wheels fit? (sigh) I spoke to my Lightning pal today, not only are those some funky truck pattern apparently but they also will NOT fit an older Lightning like his! Doh! icon_sad.gif sorry man, I'm not sure how this is going to work out but I'm pullin' for ya!
By the way, I listed a few 5 lug, 5x4 1/2" bolt circle wheels/hubs with low to no offset set-ups which may do well on an early Zcar, but I left out one source: Jeep. I didn't mention it because the hubs don't apply due to the 4WD situation. However, the wheels might be useful. Grand Cherokee and Wrangler have low-offset 5 x 4 1/2" bolt wheels so aftermarket wheels for these applications could be good.
DAW
  • 3 weeks later...
I may be wrong about Jeep as a source of 5-lug wheels/hubs. I noticed the other day that Cherokees and Comanchee (pickups) come in 2WD and that '89 Comanchee spindle/inner bearing race diameters match 240/280Z.
DAW
