Vaccuum Problem
badjuju
You are probably running around 280 for cam duration, right? Is it NA? If it is, you only have 9in/hg (30kPa) of tuning range per load band. The pressure resolution in MSExtra code is 1kPa. You can set your 12 pressure (load) bins to start at 100kPa (top), down to 67kPa on the bottom. Do 3kPa increments. If you find that you do not have anough adjustment resolution, you can always switch to Alpha-N mode, which only looks at throttle position, not manifold pressure. I think you should be able to do it in speed density (standard) mode.
