gretchen/jason Posted October 6, 2006 Share Posted October 6, 2006 So i stuffed a V8 into my z for fun even though i have tokico lowering progressive rate springs and struts to match , but yet stock sway bar id like to know where and if i can get stiffer springs to make it handle better . i have fully adjustable suspension front and rear camber and all is there a good setting for camber i have . 30 neg in the front and . 50 neg in the rear to keep up with the 80 pound speaker box i have helps with off the line traction i must say . Any advice is welcome . jason Quote Link to comment Share on other sites More sharing options...
wheelman Posted October 6, 2006 Share Posted October 6, 2006 How do you have fully adjustable suspension and still use the Tokico springs? As far as I know there are very few camber plates that work with stock diameter springs and those that do don't give much adjustment range. Are you using other methods to adjust caster/camber and ride height? If so what are they? I used those springs and don't have enough travel in the front due to the extra weight of the V8. I'll probably switch to coil-overs sometime in the future, when I do I'll also add caster/camber plates and adjustable struts. I should have gone that way right from the start. Wheelman Quote Link to comment Share on other sites More sharing options...
gretchen/jason Posted October 6, 2006 Author Share Posted October 6, 2006 I bought fully adjustable controll arms from Arizona z car . Aluminum in the front chrome moly tube in the rear all with hind joints if i said it rite . The controll arms in the front allow for all adjustments caster camber etc . In the rear it sets toe and camber very nice product no need for those caster camber plates anymore and the arms for the front i believe cost me about 400$ same for the rear . Go to http://www.arizonazcar.com and you can see what i have . So col overs are better ? I could do that i suppose and still keep my controll arms . Quote Link to comment Share on other sites More sharing options...
