Kirby260 Posted October 8, 2006 Share Posted October 8, 2006 Hey, I'm trying to find some wheels for my Z and after thoroughly searching this website, there is information about, but it comes in bits and peices. So, I thought i'd obtain some measurements and create a calculator that people can use, so instead of people asking over and over again. "Will these wheels fit under my guards" They will have a resources to determine if they will. By putting in width, size, Offset of thier rim. Then making tyre size recommendations. With adjustement options such as flares or smaller OD struts (eg coilovers) Unfortunatley I'm at college at the moment and My Z is on the other side of the country (along with my FSM and other books), so I cant obtain measurements. So I was wondering if I could convince some people to provide me with some measurements. I would like measurements to be from stock cars (ride height mainly), If you are running something different let me know. Rears: OD of stock Spring length of strut length of widest part of strut (spring, spring seat) Angle of strut from horiz or vertical, your choice. Angle of A-Arm from horiz. Depth of wheel tub Radius of edge of wheel tub (think of wheel tub as a toroid) Radius of outer body arc. Hub surface to furthest outer body point (top of body flare) Centrepoint difference between hub centre and outer body flare. That should give me enough info to do a sketch and come back with some more requests. Your involvement would be appreciated. Quote Link to comment Share on other sites More sharing options...
