okay i almost got it!!!
sone
after gettgin my ecu rebuilt and replacing the battery and fuel lines that were leakingit almost started, i had a mechanic look at it and he said i needed a new ecu and that everyhting was gettgin current except the fuel injectors, the wires connected it didnt even make a little orang spark in his screw driver look alike current tester, he said "change the ecu and it will run" i had it rebuilt cuz 450 bux for a new one was out moy budget, and it almost started (yes i am the same poster from "and i just got it" lol), so i was wondereign if any one knew of a place to find the wires i need for the l28 where i dont need to buy the whole harness for 1200 bux from a dealer, all i need is the alternator wires replaced and the six seperate connections to the fuel injectors
http://i103.photobucket.com/albums/m125/djuniorboy/101_2477.jpg
I got the injector connectors from a junkyard. Look for '90s pontiacs, I think I used a Grand Prix. Very nice connectors that you squeeze to remove/connect. No more little wire to curse at! Other late model injected cars have similar injectors, just poke around and see what you find.
