Guest Anonymous Posted October 27, 2001 Share Posted October 27, 2001 What kind of chassy work needs to be done to my 1977 280Z 2+2 for a V-8 (350) conversion? What kind of drive shaft work? Also, I've read about people putting 4-pt. cages in their Z's -- why would I need to do this? Thanx Quote Link to comment Share on other sites More sharing options...
Guest Jeff Rimmer Posted October 27, 2001 Share Posted October 27, 2001 Sub-frame connectors would be great to help, along witha cage would make your Z good and stiff. That is what I am doing with my 77 280 Z 2+2. First I must replace the rusting floor pans and frame rails. Good luck! JR Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 28, 2001 Share Posted October 28, 2001 Everything Jeff said is correct. As far as the drive shaft, it will need to get modified by a shop (if you do JTR, there is an adapter that gets installed, I believe) regardless. This is generally inexpensive and is one of the more minor items in terms of modification. Davy Quote Link to comment Share on other sites More sharing options...
