REAR BRAKE CONVERSION
Guest HIGHRPM
Guest HIGHRPM
HI EVERYONE. I'M IN THE PROCESS OF COLLECTING MY PIECES TO UPGRADE MY 260'S BRAKES. I'VE DECIDED THAT FOR THE REARS I WANT TO DO THE PRE 82 280 ZX CONVERSION WITH THE LARGE CALIPERS. I UNFORTUNATLY DO NOT KNOW WHICH OR WHOS CALIPER BRACKET I NEED TO MAKE IT WORK. ALSO, SINCE I'M CHANGING THE REARS OVER, DOES ANYONE KNOW WHICH PARK BRAKE CABLES WILL FIT??? THANKS FOR TIME GUYS!!! THIS SITE IS THE ULTIMATE !!!! icon_confused.gif
" I WANT TO DO THE PRE 82 280 ZX CONVERSION WITH THE LARGE CALIPERS."
FWIW, early 280ZX calipers are the smaller ones. Noone is offering brackets for those AFAIK, as a result of their being no bolt on solutions easily available I've pursued production of some CNC brackets. You can read their pros and info on 280zx on my web.
(hopefully prototype pair is made this coming week!)
Guest HIGHRPM
HI ROSS. NOW I'M REALLY CONFUSED. I PULLED THE LARGE REAR CALIPERS OFF OF A 79 280ZX, MAYBE I CAUGHT THE PRODUCTION DATE WRONG??? REGARDING THESE CALIPERS, WHICH ONE WOULD BE BETTER AND DOES ANYONE MAKE A MOUNTING BRACKET FOR THE SMALL CALIPERS?? icon_confused.gif
the pre 82 zx calipers which are the larger sized ones with a BIG yoke on them are a poorer design than the later caliper.
more ebrake sticking issues but IF youwant to use these then a flat bracket will mount them to the rear control arm.
the 82 calipers use a maxima bracket if you want a set of these i have a pair of new ones here. and only a 20 minute drive from delta.
"HI ROSS. NOW I'M REALLY CONFUSED. I PULLED THE LARGE REAR CALIPERS OFF OF A 79 280ZX"
Ahh, you meant physically larger. I was referring to pad size. Later ones have 25% larger pads which is a worthwhile gain IMO, as worthwhile as stepping to the 11-3/8's rotors. Early calipers work fine while in good shape as Mike says, I ran them for a few years without hassle once my current ones were refreshed. The ebrake cams in those seem to get bound up over time. They mount with a rather simple bracket, drop me a line personally if you want the detail. Your ebrake geometry and halfshaft clearance isn't ideal with that setup, as long as you know the pros/cons. I didn't notice you're right in Delta the first time. I was over their yesterday icon_rolleyes.gif , I have all parts but the actual bracket at my place if you're interested in seeing pad size, rotor size, caliper variations, & that detail I mentioned.
Guest HIGHRPM
icon_smile.gif THANKS FOR THE HELP!! I THINK THE BEST THING I SHOULD DO IS COME SEE YOU ROSS AND GET SOME EDUCATION REGARDING MY CAR. I'LL EMAIL YOU TO SEE WHEN WE CAN GET TOGETHER, AGAIN THANKS.
ROD MAKSYM
74 EARLY 260Z YELLOW
74 EARLY 260Z BLUE
