L24 EFI, Quesion about some Air plumbing
Noddle
  • Administrators
I like how you used colored lines on the pictures to ask your question. Very nice.
The purple is the Boost Controlled Decelerating Device, (BCDD). Its function is when at higher RPMS and you drop/close the throttle, it allows air to by pass the throttle valve in an effort to keep the tail pipe emissions during decel to a minimum. How you know it is functioning is that when you do drop/close the throttle, you’ll notice the RPMs will hang for a brief second or two, or when coasting, the car wont decel as aggressively at first.
If you don’t have to deal with emissions testing and you like a crisp throttle response i.e., the rpms drop rapidly when you close the throttle, then get rid of it and plug the holes. The EFI will function perfectly wit out it.
Regards,
Paul
