Wide260z Posted November 25, 2006 Share Posted November 25, 2006 I was wondering what secific dropping resistor i needed for the injectors for an 88 eccs. What does it i need to be dropped to? Secondly do i need to replace my 02 sensor with the 88 sensor? Quote Link to comment Share on other sites More sharing options...
Wide260z Posted November 25, 2006 Author Share Posted November 25, 2006 I am still in need of help. I am only getting 3 sparks after i turn the key off. Like i said it is an 88 turbo comp, in an 82 swap. I got the ignition control module from the 88 car and wired it in as the wiring diagram shows in the haynes manual. Blue pin 3, Green/black pin 5, and black ground. Still got the same thing. I AM using an MSD but i figure it should work with or without the msd. The (-) trigger wire (blue) is showing constant 4v insted of pulseing. Also... with the 1 wire 02 sensor will it just throw codes, or will that keep my car from starting? I need help Quote Link to comment Share on other sites More sharing options...
