can you swap zx rotors onto a first gen z?
Guest Anonymous
Aren't those the rotors that you use the V6 bolt on toyota wide calipers with ?(about the same size as stock 240 rotors but thicker due to being vented). Is the car going to be road raced, or do you need repeated hard stops? Might be a cheap upgrade if its a street car that doesn't demand constant repeated stops. The toyota calipers are heavy mothers though at least the narrower ones, not sure if the wide ones are, but can only assume them being heavier still. If they'll work for you, some good pads and it should stop fine, mine does with the non-vented and 4 piston toyota calipers as long as I don't ask it to do it over and over.
Regards,
Lone
Hey loe i plan to do just about everything with them.But they will have to stand up to the drag strip cuz i will go there alot next year.I was just wondering cuz if it was a direct swap then i would have done it this winter.I love the way my zx stops it has great breaks.My z does too but not as good as the zx.I plan to put the turbo rears on it along with the calipers i just wanted to upgrade to a vented front rotor. Oh ya i love these new little guys on the bottom bonk.giftwak.gifmalebitchslap.gifcoollook.gifshifty.gifflamedevil.gif
Regular Z brakes are terrible. Non-vented rotor is fade city.
The vented rotor swap can be done with the 88 4X4 toyo v6 4 piston calipers, which as both Lone and Terry in his write up (that I linked to above) mention, are very heavy. They also require spacers (extra dollars there) cuz they're wide.
Check out Terry's write up for a good explanation of the swap and the justification. I'm running the 280ZX calipers (300zx rotors) and I can tell you that it stops. The swap is basically a bolt on whichever caliper yuo choose.
