Guest milemarker60 Posted December 5, 2006 Share Posted December 5, 2006 Sorry to jump over to your board but I need some help and you guys seem to be the experts. I have transplanted a BMW M3 driveline into my Triumph TR6 which runs its power through a 95 Q45 R200 VLSD. The current ratio is factory (3.538:1) and the BMW Trans 5th gear is 1.0:1 and my tire diameter is 25". With the BMW tranny I pretty much can't use 1st gear and I'm turning 3K RPMs at 63mph. I'm trying to get it down to 2500 RPMs at 60mph so I'd like to find a supplier of ring and pinion sets for this diff. Does anyone make sets in the 3.0:1-3.3:1 range for my R200 VLSD? Any help would be greatly appreciated. Dave Quote Link to comment Share on other sites More sharing options...
karl Posted December 5, 2006 Share Posted December 5, 2006 Dave, your best bet might be to fab in a BMW rear diff. If you can shoehorn a BMW 6 into a Triumph TR6 engine bay you must have good fab. skills. I have two TR6's, 69 and a 72 and the 240z, I have been thinking about a transplant for my 69 TR. I would love to know what you had to cut up to fit the bimmer in, what did you do about the brake master cylinder? was it in the way. I have the alloy and corvair rear hubs along with the q45 diff. installed but don't know if I want to change the engine. Sorry I can't help but if anyone can you will find them on this awsome site. I'm putting a 7MGTE into my 240, mabey one might find it's way into the TR6. Well good luck Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted December 5, 2006 Share Posted December 5, 2006 Dave, I haven't heard of any for your diff (short nose R200), but there are some for the long nose R200 (I believe a 3.15 R&P set is available through Kameari in Japan, and the 260Z 2+2 manual or the 79 2+2 4 speed come with a long nose R200 3.36). An option would be to go with the R230 diff. R230s are available on Nissan Armadas (2.9375) and 300ZXTTs (3.7). Armada diffs are a little harder to come by, but if you're able to get a 300ZXTT R230 (easier to come by), you can probably swap in the Armada 2.9375 R&P set which is $295 from Courtesy Nissan (contact speeder on this site...he's doing the Armada R&P set into 300ZXTT R230 diff conversion). Check out this link: http://forums.hybridz.org/showthread.php?t=106621&highlight=armada+r230 I have some 300ZXTT R230s available for sale, but shipping might be expensive (these diffs are over 100 lbs). There's one in the classifieds that's a little closer to you, which is being sold by J. Soileau RB26zcar. Here's the link: http://classifieds.hybridz.org/showproduct.php?product=3440 Good luck on your project! Quote Link to comment Share on other sites More sharing options...
speeder Posted December 7, 2006 Share Posted December 7, 2006 I don't know this for sure, but am 90% positive that the 3.36:1 R&P from an automatic 350Z will fit that case. Both the 350Z and the Q45 utilize the later generation short nose R200, although the 350Z case is a little different externally. The mounts for the Q45 and the Armada/300zxtt diffs are very similar, but using an R 230 will require you to use a different driveshaft. The CVs you have should be Ok. The available Armada gears are 3.36 and 2.93, but to use these R&Ps my driveline shop had to use an Armada case with the 300zxtt input flange, side flanges, lsd unit, and rear cover. HybridZ member Cyrus built a 2.93 R230 and documented it here: http://forums.hybridz.org/showthread.php?t=106621&highlight=Armada Sweet hybrid, by the way. I bet that's fun. Quote Link to comment Share on other sites More sharing options...
Kongztt gt28rs MD Posted January 20, 2015 Share Posted January 20, 2015 Would I lose abs if I use the armada r230 and swap the z32tt lsd.. Output stubs and rear cover? I read on a few pages where the abs mounts need to be pressed off the z32tt rear cover. Could I just machine the outside of the r230 armada for clearance so that the abs sensor can still be used with the z32tt output stubs? This is going on a 300zx twinturbo that I am planning on using a 370z 6 speed transmission with.. So my more desirable rear ratio is the armada ~2.9 Quote Link to comment Share on other sites More sharing options...
