Flywheel/flexplate ring gear replacement?
HizAndHerz
Can the ring gear on a auto transmission flex plate be replaced? What kind of shop would do this?
We're going to end up with another 280z with the L4N71B 4-speed autotomatic with lockup overdrive, but the flexplates have chewed up ring gears. The gear appears to be tack welded on so I'm assuming that it can be replaced by someone that can get the correct replacement gear and then rebalance after welding.
Thanks!
