gts link
Guest TeamNissan
Guest TeamNissan
Anyone have any usefull info about the gts link ecu? Can you run it in map (D Jetro)? I need a easy stand alone for a rb itb set up for under 1k that I can install myself. I would be thankfull for any help guys.
http://www.linkecu.com/ is the manufacturers website. As far as I'm aware the gts link is pretty cheap and easy to install. I've heard of a few people having cold start problems tho. This seems to have been addressed in their most recent releases the G2 and G3. The G3 is way ahead of the gts link and pricing is pretty similar. Only thing is that it is wire in rather than plug in. Alternatively you could buy an adapter for the G3 but that'll put you over your 1k limit...
I myself am going for the more expensive G2 because I'm wanting a bit of extra control and monitoring of the engine.
Hope that helps
Wes
