Guest nx2000de Posted January 8, 2007 Share Posted January 8, 2007 alright i just bought a 73 240 with triple weber sidedraft setup and i would like too know what everyone else on this forum uses too clean out the fuel system becouse the car has been sitting for a little while.... Quote Link to comment Share on other sites More sharing options...
zspeed22 Posted January 8, 2007 Share Posted January 8, 2007 Sea Foam is good stuff pour some in your gastank pour alittle down each carb make sure to run it threw the carbs at about a constant 3000 rmps will smoke alot but help clean alot of things up. Quote Link to comment Share on other sites More sharing options...
cpt jack Posted January 8, 2007 Share Posted January 8, 2007 Sea Foam is good stuff pour some in your gastank pour alittle down each carb make sure to run it threw the carbs at about a constant 3000 rmps will smoke alot but help clean alot of things up. yea but what if ur car doesnt have carbs how u do it fuel filter? Quote Link to comment Share on other sites More sharing options...
Guest nx2000de Posted January 8, 2007 Share Posted January 8, 2007 thanks for the info Quote Link to comment Share on other sites More sharing options...
zspeed22 Posted January 8, 2007 Share Posted January 8, 2007 Not quite sure what you are asking about the fuel filter you can still run the Sea Foam threw the gas it will clean your injectors out. Also for the fuel injector guys on my 300zx i just pulled the Brake booster line off that is "T" into the intake manifold and you can clean the carbage build up that way or spray your throttle body out with some Carb cleaner that will also help with some bad idle proablems kinda a stray from the topic but it works wonders as well for the car to run smooth. Quote Link to comment Share on other sites More sharing options...
