defrag010 Posted January 13, 2007 Share Posted January 13, 2007 I have done alot of reading/searching on it, and people say it's not possible because the caliper is threaded and the mount on the zx are not. Other than the threading issue, is there anything that prevents it from working? I can take care of the thread issue as long as the caliper will still mount the same way as it would on a Z. I'd assume I would have to do the same 4-lug Z31 rotors w/ spacer as the Z also? Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted January 13, 2007 Share Posted January 13, 2007 i tried this, seems that it would work, i got the calipers, marked sw on the side (these are the wide ones) so im gonna try one day. you are correct aboot the threading thing tho. id say make an offset adapter to maintain bolt diameter Quote Link to comment Share on other sites More sharing options...
defrag010 Posted January 14, 2007 Author Share Posted January 14, 2007 I was just thinking of drilling the threads of the caliper out smooth, and putting either helicoils or time serts in the hub mount that are the right diameter. Quote Link to comment Share on other sites More sharing options...
