Weber specs 32/36 DGV for 240-280 Z duel carbs
Here comes trouble
weber dual downdraft 32/36 DGV 5A specifications for 240-280 Z Part Numbers Main Jet Primary....................#73801 . Main Jet Secondary................#73801 Secondary Idle Jet................ #74403 Primary Idle Jet....................#74403 Needle....................... .......#64900.001 Needle valve ..............# 79519.200 Primary emulsion tube...........# 61440.216 secondary emulsion tube ..... #611440.211 Primary Air Corrector jet.......#77201 Secondary Air corrector Jet . #77201 Main Primary jet....................#73801 Secondary main Jet .........#73801 . Float..............................# 41030.20 Power valve...... # 64235.016 Settings PrimaryMain Jet ............... 1.40 mm Secondary Main Jet................ . 1.35 mm Primary Idle Jet.................... .55mm secondary Idle Jet................. .50 mm Needle Valve........................ 2.00 mm Primary emulsion tube......... F50 secondary emulsion tube ..... F6 Primary Air Corrector jet....... 1.65 mm Secondary Air corrector Jet.....1.60 mm Primary Venturi..................... 26 mm secondary venturi..................27 mm Primary Auxillary Venturi..... 3.50 mm Seconadry Auxillary ventuiuri...3.50 mm Float measurement ..........46.5 mm Needle Valve ..................2.00 mm Pump Jet ......................2.00 mm.. Secondary idle jet ..... .50mm Primary idle jet ..... .55 mm Primary venturi ....26 mm Secondary venturi ....... 27 mm
