z bomb Posted February 13, 2007 Share Posted February 13, 2007 My Z doesn't start. Did some tests out of Clymer (if you've got one, check this out) and it produced some wierd results. I'll list what I know... 1: Got fuel. 2: Got 12.4V battery wise, and the starter works. 3. No spark out of coil. My friend said he saw it arcing from the coil to ground on the fender well. 4: Coil is getting voltage. 5: Unhooked (-) coil terminal (capacitor) and it drew .0001V I believe, with points open. 6: Voltage at (+) terminal on coil went from .5V to nothing, maybe .0001V. Clymer says this condition is distributor failure. I have a brand new coil, ballast resistor, and points. I replaced the coil due to the fluctuating resistance I got out of it, and purchased the rest for good measure. All didn't work. Before I spend money and time with a dizzy, maybe the ignition switch itself? I will test the coil (+) while cranking, and see what happens, but anybody know of a dizzy failing or grounding out? Thanks for any help in advance OOPS- also called Rob at Z car garage. Never heard of dizzys failing, but also didn't seem like he felt like talking. Thus hybridz. Quote Link to comment Share on other sites More sharing options...
getZ Posted February 14, 2007 Share Posted February 14, 2007 what year and what type of engine do you have? Quote Link to comment Share on other sites More sharing options...
z-ya Posted February 14, 2007 Share Posted February 14, 2007 If the coil is arcing to the body, then you most likely have a bad coil wire. How old are the wires? Putting a new set of Bosch or NGK wires on there may solve you problem Quote Link to comment Share on other sites More sharing options...
z bomb Posted February 24, 2007 Author Share Posted February 24, 2007 Update: Thought my coil was bad due to voltage getting to it and it not working. But lo and behold... It was the condenser. I didn't know this, but when the condenser fails, it soaks up voltage, like a voltage black hole. Thanks for the interest! Quote Link to comment Share on other sites More sharing options...
