les Posted February 14, 2007 Share Posted February 14, 2007 Fellows, Does anyone know if the Getrag 6spd units (v160) in the SupraTT & the Nissan Skyline Getrag unit are the same. The project is an Imsa GTP VG30 engine in a Z31 . Apparently the stock tranny is good for 500-600 hp but the car will be running 800 whp and a more durable solution is needed . Apparently, the imput shaft on the Toyota is much larger than the z31 unit. I think the imput shaft is 1.33 inches compared to the z31's tranny's appoximate 0.92" inches. Is there any way that one could put the imput shaft of a Nissan getrag trans in the Toyota Getrag trans? This way a Nissan clutch setup can be used? Do you guys see any other impediments to using the V160 besides the fact one would have to fabricate an adapter plate. Perhaps you have suggestions on other durable trans solutions. Thanks for any help. Les Quote Link to comment Share on other sites More sharing options...
510six Posted February 14, 2007 Share Posted February 14, 2007 If your looking for a durable 6 speed a T56 can be upgraded to handle over a 1000hp.I have a Rockland Standard Gear 750hp kit in my T56 with an adaptor bellhousing to an L series motor.You could have a similar bellhousing made from a Z31 T5 bellhousing and use Nissan clutch pieces.It is easier to have a custom clutch disc made than to change input shafts.Holding 800 hp is something that no stock type clutch will do, a twin disc unit will have to be used. http://www.rsgear.com/RacePerformancefiles/frame.htm Quote Link to comment Share on other sites More sharing options...
Trevor Posted February 14, 2007 Share Posted February 14, 2007 How about using a Supra Disc and Tranny with the 300ZX clutch plate? Quote Link to comment Share on other sites More sharing options...
les Posted February 15, 2007 Author Share Posted February 15, 2007 Tranny not holding power is the problem. Using the Supra clutch/flywheel won't change that. Quote Link to comment Share on other sites More sharing options...
510six Posted February 15, 2007 Share Posted February 15, 2007 If you would like the contact information of the people who helped with the adaptor bellhousing PM me. Quote Link to comment Share on other sites More sharing options...
