Resonated tips on GTO rebody
Zerrari GTO
Since I am doing the Ferrari re-body with a V8 I am going to run dual exhaust with some type of dual quad tip set-up. I've got an RX7 fuel tank mounted in the back which allows good access for duals on both sides (also added another cut out to the rear crossmember).
My plan is to have 2 1/4" pipes, a couple flow through type mufflers (glasspacks) tucked into the transmission tunel like I have see on several Z's followed by a couple more near the back. My question is this: To give the car the proper "look" I should probably use a couple resonated dual tips (Monza/Ansa type). The resonated tips look like they would cause a lot of restriction and I've never heard these used on a V8 and wondered what kind of sound they created. Can someone please educate me on resonated tips and what to expect if I do use them. All feedback would be greatly appreciated.
Thanks.
