Spark on a VG30DE???
1FASTKINGCAB
You can fit a Megasquirt-I with six coil drivers, but not a Megasquirt-II. The standard MS-II firmware only has one ignition output channel, and even the alpha codes I've seen only have four channels.
The trouble is finding an appropriate ignition trigger - I know many of the Nissan CASs use the length of the slits for cylinder identification, which does not work with current Megasquirt firmware. MSnS-E can trigger off a missing tooth wheel or a combination of a one tooth cam trigger and an equally spaced tooth wheel.
Or you could fit it with a Ford EDIS ignition - that's the most well documented and popular method for distributorless ignition.
