Wire up grounds and wire 28 up to power inverter so communicate with pc?
280zwitha383
I know I'm dangerous so I thought I would ask before I try this. I have a 12v power inverter and I just loaded Megatune 2.25 onto my OLD trusty laptop. All I really want to do is establish that I CAN communicate between the two (maybe retrieve the VE table from it or something similar). From the diagram I get that wires 7,8,9,10,11, and 15 are grounds and wire 28 is just straight power. No fuse but I've used the inverter many times and never burned anything up yet and don't plan on crossing any wires. Is this a sound idea? Why so many grounds? Thanks.
do you have a stim board to hook up to it?
otherwise thats probably all you will get. The stim board completes the circuits for the iat, o2, clt, rpm, and tps, as well as providing power.
get one!
on another note, you should be able to connect with your pc by just providing power.
Ok, I got it connected to my desktop and poked around a little bit. I'll have to spend a little time and try to figure out what's using my COM1 port on my laptop. It just says unable to open in Megatune and Hyperterminal says that another program is using it. Any ideas? I've got an old Armada, 233mhz, 160mb ram, windows XP. I'm about to compare running services in msconfig. If that doesn't work I really don't have much more of a clue. I've already closed every running program other than the system files with no luck.
