QWKDTSN Posted March 7, 2002 Share Posted March 7, 2002 I'm pretty sure I'll be doing a 5-lug swap sometime in the next couple of years and I'm just curious whether or not the 9-inch TT rears will fit or if the NA set is the biggest I can go on stock fenders. How's the offset on these wheels? I'm going to do ZG flares so I wonder what kind of widths/offsets would fill those up nicely and take up the maximum amount of room available between the coilover and the flare. Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted March 7, 2002 Share Posted March 7, 2002 I was under the impression that the TT rears were 8" and the fronts (all four on a NA) were 7". I could be wrong though. (If I am give me this .) Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted March 8, 2002 Author Share Posted March 8, 2002 I'm pretty sure the NA wheels are 8" front 8" rear and the TT wheels are 8" front 9" rear. Can anyone verify this? Quote Link to comment Share on other sites More sharing options...
Guest scca Posted March 8, 2002 Share Posted March 8, 2002 NA rims are 7.5 all around this is what is on my car now TT rims are wider on the rear only AFAIK. Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted March 8, 2002 Share Posted March 8, 2002 Check out www.aaarims.com . Here is the text from the 1990-1996 300ZX Page: 16x7-1/2 in., 5 lug, 4-1/2" lug pattern. 5 slanted spokes. Please specify right or left side. 16x8-1/2 in., 5 lug, 4-1/2" lug pattern. 5 directional, slightly slanted spokes. (Note: Rear wheels, Turbo). Please specify right or left side. So, all fronts were 16x7.5 and NA rears were 16x7.5 while turbo rears were 16x8.5. Quote Link to comment Share on other sites More sharing options...
Ray Posted March 8, 2002 Share Posted March 8, 2002 I am doing the same swap and have test fitted the turbo wheels in the back. I still have to mount some tires and double check but just test fitting the wheels they looked ok. Now I am going to test fit a 245/50/16 first to see if they will fit I have a fealing they will rub... If they dont fit then I will go with the 245/45/16... Do a search mike posted what spacers he was using to get the N/A wheels to work.. If I hadn't got a great deal on the TT wheels I was going to buy some N/A wheels just because they fit no problem..... Good luck when I get the tires mounted I will post somthing.... Quote Link to comment Share on other sites More sharing options...
