any knows differences between n60 and n62 maf??
if i´m in true i know this:
n60 is a q45 maf?
n62 is a z32 maf?
it´s similar both mafs? i know the pinout is same, the inlet diameter is the same, but the resitance(ohms) are the same? the output voltage is the same?
can a n60 maf work well with a n62 reprogramed ecu? it´s possible that the a/f reads too rich for the reason that i put a n60 maf with n62 reprogramed ecu?
i´m thankfull for all the help that you can provide to me.
thanks.
