24ounce Posted March 11, 2007 Share Posted March 11, 2007 well i searched and didnt find anything - this is my first engine build and its a 3.1 with l24rods with floating pins on standered ka24 pistons i know the pin in the piston is offset to stop thea slap garbage and the rod has to be a certian way for the oiler so now if im looking at the front of the block which way should the oiler be facing right or left? and should the short side of the piston be on the left or right? also according stonehinge i need to use a sealers on the rear main cap - what should this be just any regular permatex or dose it need to be somethign special?? also should i be using any certian kind or assembly lube or will anythign i pick up at a parts store be just fine? Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted March 11, 2007 Share Posted March 11, 2007 the oiler faces the thrust side....i think its the passengers...im not 100% sure... Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted March 11, 2007 Share Posted March 11, 2007 rear main cap use permatex ultra grey...do it where the haynes manual shows....make sure to get the correct rubber side seals from the dealer! any assembly lube will be fine...just crank it over with no ign to get oil pressure after its put togehter! Quote Link to comment Share on other sites More sharing options...
24ounce Posted March 11, 2007 Author Share Posted March 11, 2007 allright perfect thats the way i figured the rod went thanks the pstion is the one im not sure Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted March 11, 2007 Share Posted March 11, 2007 theres a notch on the piston....that faces front... Quote Link to comment Share on other sites More sharing options...
24ounce Posted March 11, 2007 Author Share Posted March 11, 2007 theres a bunch of notches but on both sides but i found one indent on top of the piston thats on every piston but only one side so that must be it the notch faces the front of the motor?? thanks bubbles Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted March 11, 2007 Share Posted March 11, 2007 yeah...those little square looking notches face the front of the motor!!! glad i could help! get that thing put together and broken in, and lets go to sez! Quote Link to comment Share on other sites More sharing options...
